Phantomebb
May 17, 2014Aspirant
WNR1000v3 Speed caped through router wired! 9.5mbps max. Please HELP!
I am pretty much at wits end. So here the story. About 4 days ago I noticed my internet speed running slow on the ethernet cable straight to the back of my computer and testmy.net showed I was gett...
Retired_Member
May 17, 2014So the wall connection you refer to is connected to Comcast modem/router and delivers 55 which is correct?
One problem is you have what's called a double Nat, you shouldn't connect a router to another. You should buy a gigabit switch or a Access point if you need additional wireless coverage.
