shinobi1173
Jan 10, 2014Novice
WNR2000 cannot connect to WNDR3300!
I am pretty sure I am on the right thread. Sorry, I am new to forums. Well, I am attempting to setup a WNDR3300 and WNR2000v2 repeater combo with the WNR2000 as the repeater. On the base station (...
jmizoguchi
Jan 10, 2014Virtuoso
Good try...
FYI for future post post under the model you own. In your case it will be here in below url in root of the section
http://forum1.netgear.com/forumdisplay.php?f=32
54Mbps/WEP or no security so you are in right setup already
(about a 20-30 ft distance and a wall corner as obstruction).
Make sure you are not placing the 2nd unit where wifi device originally get low signal. You need to overlap the signal to work so you will need to place 2nd unit closer to the main router so that I can't repeat the signal to cover the section that you has low signal
