shinobi1173
Jan 10, 2014Novice
WNR2000 cannot connect to WNDR3300!
I am pretty sure I am on the right thread. Sorry, I am new to forums. Well, I am attempting to setup a WNDR3300 and WNR2000v2 repeater combo with the WNR2000 as the repeater. On the base station (...
shinobi1173
Jan 10, 2014Novice
Thanks for the prompt reply. Ive read so many of your posts in the past and you have fixed many of my problems. Haha youre nearly a hero to me.
Well, unfortunately where I currently have the wnr2000 is the closest I can get it (I want to hook it up via Ethernet cable to my xbox and.dvd player). I am pretty sure the signals overlap since its only 20ft or so from the base. Any other ideas? I read somewhere that I should disable dhcp. Is.that true?
