dstx144
Feb 04, 2021Tutor
wnr2000v3 in initial setup not connecting with reolink ip camera
I recently got a Reolink Argus 2 wireless camera for a gift. I connot connect with initial set up instructions provided by reolink. I own an additional Reolink RLC-410WS camera with 3 more YI camera...
Feb 04, 2021Guru - Experienced User
You're running the argus 2 plus the rlc-410ws and 3 other cameras? (plus whatever other devices you have on the network)
It might be time for a router upgrade.
The wnr2000 is a base model N300 device and you're attempting to run 2x HD camera's off it plus 3 other Yi camera's.
The argus and the rlc both support 5gzh connections because of their increased bandwidth. It might be prudent to look at a dual band router becase thats a heck of a burden on that little N300 router.
Not saying that's whats causing the issue but just putting it out there because I'm surpriced you haven' thad issues yet.
Does the camera connect if the other cameras are shut down and the router rebooted?
- dstx144Feb 04, 2021Tutor
The Argus 2 and the RLC 410 both are specifically for a 2.4 Ghz router according to the user manual for both cameras. When I go in the settings of the router and downgrade the security settings from WPA-PSK/WPA2-PASK to no security option the camera will connect to the router on initial setup and function normally along with the RLC-410WS but the 3 other YI indoor cameras drop off and loose connection with router.
I will try it the reverse way as you suggested, stay in security mode but disconnect other cameras and see what happens.
OK, does appear I was over doing it with the cameras. After I disabled YI cameras, initial setup for the argus 2 went smoothly. Time to upgrade! Thanks for your input. Cheers!
- plemansFeb 04, 2021Guru - Experienced User
the RLC-410ws is a dual band 4megapixel camera.
https://www.amazon.com/Reolink-RLC-410WS-Wireless-Security-Camera/dp/B019MMABCI
the argus 2 is not a dual band but it is a 1080p 2megapixel camera.
not sure what you're other 3 camera's are but that's quite a burden on 2.4ghz. 2.4ghz is slow and sensitive to interference.
Its why we recommend people doing zoom/streaming video/gaming be using 5ghz. its much much faster (but shorter range) and suffers from less interference.
Again, not saying thats the issue but its definitely a burden on the 2.4ghz networks. Especially if you're using other devices on it (roku, phones, computers, etc)
