dstx144
Feb 04, 2021Tutor
wnr2000v3 in initial setup not connecting with reolink ip camera
I recently got a Reolink Argus 2 wireless camera for a gift. I connot connect with initial set up instructions provided by reolink. I own an additional Reolink RLC-410WS camera with 3 more YI camera...
dstx144
Feb 04, 2021Tutor
I will try it the reverse way as you suggested, stay in security mode but disconnect other cameras and see what happens.
dstx144
Feb 04, 2021Tutor
OK, does appear I was over doing it with the cameras. After I disabled YI cameras, initial setup for the argus 2 went smoothly. Time to upgrade! Thanks for your input. Cheers!
- plemansFeb 04, 2021Guru - Experienced User
Glad you got it figured out!
- dstx144Feb 13, 2021Tutor
UPDATE!
Just bought and upgraded to a netgear AC1600 (Brand New) buutt its not connecting to the internet. Shows it as connected but absulotely no speed. Did a speed test and shows 75 kbps. Then connected staight to modem via ethernet, it works great. There has to be asetting that is not right. Any feedback on this new issue would be appreciated!
- plemansFeb 14, 2021Guru - Experienced User
What modem/gateway is it connecting to?
