Jademalo
Apr 07, 2012Aspirant
WNR2200 Port 80 issue
Right, I've spent three hours on this and am completely out of ideas. I have port 80 forwarded to a webserver on 192.168.0.10 I can connect to this fine with 192.168.0.10:80 If I use http://www...
jmizoguchi
Apr 07, 2012Virtuoso
Jademalo wrote: Bit more info - if I unforward the port and try to access it from a PC on my network using the external IP, it doesn't work. If I forward it, it does - but no log entry is created.
if works but no entry in the log then contact support with bug report using portal at my.netgear.com
forum will not going to have any solution to this unless you put trouble ticket
