Jademalo
Apr 07, 2012Aspirant
WNR2200 Port 80 issue
Right, I've spent three hours on this and am completely out of ideas. I have port 80 forwarded to a webserver on 192.168.0.10 I can connect to this fine with 192.168.0.10:80 If I use http://www...
Jademalo
jmizoguchi wrote: if works but no entry in the log then contact support with bug report using portal at my.netgear.com
forum will not going to have any solution to this unless you put trouble ticket
It only works if I'm on the local network connecting with the external ip though. I'll make a ticket, my problem is the last issue I had completely ignored my question and told me to reinstall the firmware. Which I've tried for this problem and didn't work.
