Jademalo
Apr 07, 2012Aspirant
WNR2200 Port 80 issue
Right, I've spent three hours on this and am completely out of ideas. I have port 80 forwarded to a webserver on 192.168.0.10 I can connect to this fine with 192.168.0.10:80 If I use http://www...
Jademalo
Apr 08, 2012Aspirant
Sorry for the amount of posts, but they're uneditable. Another thing I've discovered is that if port 80 is forwarded, you can't use the local router USB connect, even though it's only the router's local port 80. It throws an error, though.
But, if this is set and you try to forward the port manually, it does not throw an error, But instead doesn't work at all
