Noah-needs-help
May 09, 2021Aspirant
Wondering if it’s worth getting the ex7700
I have a xr450 router and it works pretty well but in my room it’s speeds drop quite a bit and was wondering if it’s worth getting the ex7700 to use for my phones and also using an ethernet in it for ...
Noah-needs-help
It’s a average size house not super small. My room is in the basement and my router and modem are all the way upstairs in a corner of the house. Idk why at&t put it there but because it’s fiber i don’t think it can move. As for the walls I don’t know what they’re made of. And also I’ll be using the ethernet ports from the wifi extender is it still not worth it with that?
May 10, 2021Guru - Experienced User
You can use the ethernet ports on the extender. I"m just saying if the location the extender is in doesnt have signal than the extender will function poorly
