terry0729
Nov 24, 2011Follower
WPA2 Passphrase and Full key (WPN824v3)
Now that my wife has a relatively new device (iPAD), I decided to upgrade the home network from WEP to WPA2-PSK. The router accepts a passphrase and my two i-devices only require that to sync up. How...
jmizoguchi
Dec 04, 2011Virtuoso
Did you try WPA?
Kindle should support higher than WEP. I would double check spec on kindle
