terry0729
Nov 24, 2011Follower
WPA2 Passphrase and Full key (WPN824v3)
Now that my wife has a relatively new device (iPAD), I decided to upgrade the home network from WEP to WPA2-PSK. The router accepts a passphrase and my two i-devices only require that to sync up. How...
Chart
Dec 04, 2011Novice
Straight from Kindle:
Ensure you've entered a complete WEP or WPA key.
Some brands of wireless routers automatically generate a simple text passphrase from the WEP key. The Kindle is not compatible with passphrases. You must enter the complete WEP key, which contain letters a-f and numbers 0-9. WEP key lengths are as follows:
64-bit WEP keys -- 10 digits
128-bit WEP keys -- 26 digits
256-bit WEP keys -- 58 digits
WPA keys have a minimum of 8 characters and a maximum of 63 characters, and are case sensitive.
Wi-Fi Router Issues
If you are having difficulties connecting to your Wi-Fi network, ensure that your router has not exceeded the maximum number of devices that can be connected at one time. Kindle can connect to N, B and G type routers and to WPS enabled networks.
Kindle is currently unable to connect to enterprise / peer-to-peer networks. If your router has MAC filtering enabled you will be unable to connect if your Kindle's MAC address is not added to your router's whitelist. In order to see your network, your router channel must be within the range 1-11.
Connecting via WPS Technology
Kindle will recognize Wi-Fi networks with a WPS compatible router. To connect via WPS ensure you press the WPS key on your router and are within range of your Wi-Fi network when selecting “Connect via WPS” on the Wi-Fi setup process.
If you are out of range of your wireless network or the WPS key on the router has not been selected when you attempt to connect via WPS you may receive an error stating “WPS connection failed”. This message may also display if you have MAC address filtering enabled.
You may want to contact your Internet service provider or router manufacturer for assistance with troubleshooting your home network.
Router Restriction Compatibility Requirements
WEP Security
Security Key
64-bit WEP keys --10 Digits
128-bit WEP keys--26 Digits
256-bit WEP keys --58 Digits
Passphrases are not supported
WPA Security
Pass Key
Must be 8-63 digits in length
Wi-Fi Router Issues
WEP Security
Security Key
WPA Security
Pass Key
