terry0729
Nov 24, 2011Follower
WPA2 Passphrase and Full key (WPN824v3)
Now that my wife has a relatively new device (iPAD), I decided to upgrade the home network from WEP to WPA2-PSK. The router accepts a passphrase and my two i-devices only require that to sync up. How...
jmizoguchi
Dec 04, 2011Virtuoso
If kind only offer WEP then 2.4GHZ must WEP
You change router to push other thans WEP when wifi device only supports WEP
If you dual band router with guest account capable use kindle in guest account while test of better wifi device can use WPA2 on primary guest account
