bonzoWiltsUK
Dec 07, 2024Initiate
WPN802v2 browsers say connection not secure
WPN802v2 Windows 10 I cannot log in to the access point as the browser (e.g.) reports that (e.g. for Edge) : ' The connection for this site is not secure 192.168.0.231 uses an unsupported protoc...
- Dec 08, 2024
Holy jezz, that thing is 19 years old. Its time to retire it and get something from this decade. Its on old b/g router with super slow speeds. Unless you're on 2-6mbps dialup/dsl, this thing is bottlenecking big time. Get ride of it.
Dec 08, 2024Guru - Experienced User
bonzoWiltsUK
Dec 08, 2024Initiate
Thank you plemans! I get the hint.
I kind of feared the truth, always reluctant to add to the world's pile of junk.
- plemansDec 09, 2024Guru - Experienced User
I'm not a fan of throwing things away either but since b/g, you've had wireless n, then AC, then AX, then AX 6ghz, and now BE, You're so far behind that if you have any decent speed at all, you'll see a massive performance boost with an upgrade.
