AurelWD
Jul 02, 2014Follower
[WPN824EXT] Can't access to config webpage
Hi. I have a wired connection between my computer and my router netgear on slot 1 and wired connection between my gateway and my router on the yellow slot. My 2 RJ45 are the same. First, I have rese...
wmars1776
Jul 17, 2014Novice
AurelWD wrote: Hi.
First, I have reseted my device to factory settings.
The router is working correctly however I can't access to config webpage through my internet browser using http://192.168.0.1 or http://192.168.1.1 or http://www.mywifiext.net/ or http://www.mywifiext.com/
Pathping to my gateway don't give my my router IP adress.
Help will be appreciated a lot, thank you.
Go to network and sharing center. Click on map network see full map. When that opens click on the icon labled WN2500RP or the name of your extender. The website will open!!!
