NGDiracDeBrogli
Oct 13, 2011Aspirant
WPS security on the WNDR3700-4000 series
Router WNDR3800 / firmware: v1.0.0.18 / Windows XP SP3 Hi, What happens if my router is requested to set up a very first WPS client and the box [Keep Existing Wireless Settings] is ENABLED? ...
NGDiracDeBrogli
Oct 14, 2011Aspirant
jmizoguchi wrote: diable PIN for WPS
Done that already.
jmizoguchi wrote: WPS it will not initiate without pressing the WPS button and it need PIN number for WPS capable wifi devices so in essence someone can not connect using WPS
Not true. One can use Push 'N' Connect to establish a WPS connection. In that case there are no passwords, no passphrases nor any PIN numbers involved. Have a look at the WPS (Push 'N' Connect) procedure on page 20 of the following document:
http://www.downloads.netgear.com/files/WNDR380/Documentation/UM/WNDR3800_UM_8Sep11.pdf
Noteworthy to mention is that the procedure to establish a WPS connection --- be it a Push 'N' or PIN number method --- is essentially of no relevance to my earlier question. So I am coming back to my previous question:
Is it possible on a 3700-4000 router to set up a first-time WPS connection (there are no other WPS networks on the router yet) while the box [Keep Existing Wireless Settings] is ENABLED? Or, is that under those conditions impossible? Is there anybody who could do the test because I don't have a laptop that supports WPS.
J
