Lisadw
Oct 20, 2022Follower
Wrong wifi password
We have been trying to connect the Netgear AX1800 wifi extender to our network but after we select our network to connect and try to put our password in it is saying the password is incorrect. We have...
michaelkenward
Oct 21, 2022Guru - Experienced User
What router are you connecting to?
How are you connecting the extender?
Have you tried WPS?
Which Netgear device do you have?
AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
If this really is an extender, then this isn't the best place to ask for help.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
You might like to search there for messages related to your problem.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
