Lilybetty
Apr 21, 2021Aspirant
Wx6120 extender, says incorrect password
I have the right password, it keeps saying it’s incorrect, please help I’ve done the reset and that didn’t work
Lilybetty
Yes that’s the model , I don’t know what you mean by firmware ?
Connected to a Vodafone router using wps as just got an error message when on computer
Thanks
Thanks
Apr 21, 2021Guru - Experienced User
firmware is the software (firmware) running the device.
Vodafones wps function doesn't always work as it should.
Try factory resetting the extender (push and hold reset for 7-15 seconds while extender is powered on), then reinstall it using the installation asssistant and NOT WPS.
- LilybettyApr 21, 2021AspirantAll the green lights are on so I presume the wps worked. I tried resetting it but I can’t do the computer way as I get this screen...
- plemansApr 21, 2021Guru - Experienced User
When you were resetting, did you push and hold reset for 7-15 seconds while it was powered on?
WPS can get coded different and even though the colors show proper, it not work right.
- LilybettyApr 29, 2021AspirantYes held for 30 seconds to make sure. I keep trying every few days but still it says password incorrect
