mmitsch's avatar
mmitsch
Tutor
Sep 21, 2024
X6 AC2200 EX7700
We would like to get an extender for our R8000 AC3200 Nighthawk Router. I was wondering if the X6 AC2200 EX7700 will work?
We have a large 2 story home and are having some dead spots.
Could you let us know?
  • plemans's avatar
    Yes. It'll work.
    the EX7500, EX7700, and EX8000 will work
    • mmitsch's avatar
      mmitsch
      Tutor
      Thanks!
      Will I be able to connect to the same network seamlessly? Haven’t used one if these bef.
      Appreciate your answer.
      • plemans's avatar
        If you set it up in mesh mode "one wifi" mode, it will.
        If you're needing more than 1 extender, I'd recommend moving to an actual mesh system but if you're only needing 1 extender, thats a good option. they're pretty cheap off fleabay/renewed.
