BretD
Aug 29, 2017Administrator
X6S - The First Nighthawk® Tri-Band WiFi Range Extender EX8000
Turn dead-zones into fun-zones.
Now you can easily build your own powerful extended WiFi network. Enjoy all the advanced router features that a Nighthawk has to offer and easily build your own ...
scss98
Dec 17, 2017Guide
I would like to pair 2 of these this with the R8000p Router. However, I would like to use CAT6 wires to connect the Extenders to the Main Router. The owners manual seems to suggest this can be done. However, it does not describe whether I will still be able to use ONE SSID and have Smart Roaming. Those appear to only apply when you use WIFI to connect the extenders. I have thick concrete walls in my home and WIFI is not a solution, I need multiple access points to project WIFI coverage.
