dc8flyer's avatar
dc8flyer
x6S AC4000 extender
At about 30 feet the signal isnt good enough for a 2.4GHZ exercise bike.
What extenders work well with the AC4000?
Do the extenders have both 2.4 and 5GHZ capabilities?
Am I limited to Netgear extenders or would other products work just as well?
I'm looking for specific products that work with the AC4000 so I can research further. I am not that familar with what or how these extenders work to start so specific ones can get me started.
Thanks.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Anything should work with the R8000P listed in your footer.
    (AC4000 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.)
    Pick what you want. Most will deliver both.
    No and yes. Take your pick. It can be easier to stock with one brand because you get used to their controls.
    This would be a good place to start:
    WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
    Feed in your circumstances. Check back here for user experience.
    Not sure why you posted in the "app" section, this is a better place to ask about extenders:
    WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
