avtella's avatar
avtella
Prodigy
Sep 06, 2017
X6S AmA – What WiFi chipset snd CPU does it use.
What chipset for WiFi and CPU does the X6S use.
1 Reply
  • hi
    see
    CPU1: Qualcomm IPQ4019 (717 MHz, 4 cores)
    FLA1: ? MiB (Brand? Model?)
    RAM1: ? MiB (Brand? Model?)
    Expansion IFs: USB 2.0
    USB ports: 1
    WI1 chip1: Qualcomm IPQ4019
    WI1 chip2: Qualcomm IPQ4019
    WI1 802dot11 protocols: abgn+ac
    WI1 MIMO config: 2x2:2
    WI1 antenna connector: none
    WI2 chip1: Qualcomm Atheros QCA9984
    WI2 802dot11 protocols: an+ac
    WI2 MIMO config: 4x4:4
    WI2 antenna connector: none
    ETH chip1: Brand? Model?
    LAN speed: 10/100/1000
    LAN ports: 4
    pretty much exactly the same as the orbi system
     btw if you google make and model name followed by chipset you will get the wikidevi web site for that model
    eg
    https://wikidevi.com/wiki/Netgear_EX8000
