Rostklopper's avatar
Rostklopper
Follower
Feb 16, 2022
X6S EX8000 Webinterface nicht erreichbar
HALLO, HABE EINEN X6S GEBRAUCHT GEKAUFT UND ÜBER WPS EINGERICHTET .  ES FUNKTIONIERT ALLES WUNDERBAR  AUCH ÜBER DIE APP. ABER WENN ICH MICH ÜBER DAS WEBINTERFACE AUF DEN REPEATER ANMELDEN MÖCHTE (...
  • plemans's avatar
    Feb 16, 2022
    did you factory reset it?
    Push and hold reset for 7-15 seconds while powered on.
    that'll get you back to the defaults.
    default login: admin
    default password: password
    All lower case.
    then you can reset the login password
