JAM66's avatar
JAM66
Follower
Nov 25, 2017
X6S Extender - as a wired extender
Does anyone know if it is possible to have the Nighthawk X6S Tri-Band WiFi Range Extender (ex8000) used as a wired extender to an existing wireless network with the same SSID. I have a Netgear Nighthawk x10 router. I wanted to use the extender in my basement where I have cables that run back to my router. I tried setting up in AP mode as well as extender mode and I'm having a very difficult time getting it work. Any suggestions before I send this overpriced thing back?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Yes that should work can you give more detail on the issues you are having?
    DarrenM
