sfinn's avatar
sfinn
Guide
Jun 14, 2022
X6S Mesh Extender/C7800 keep disconnecting
I've a C7800 provisioned by xfinity and an EX8000 extender (firmware v1.0.1.240) extender. They are (almost) line-of-sign through a doorway. The EX8000 disconnects from the C7800 at least once daily, and often more frequently. By disconnect I mean that devices connected to the EX8000, either by wire or wifi, are no longer connected to the network through the C7800. The C7800 doesn't show them as devices, and doesn't show the EX8000 as a device. BUTI can generally connect via web browser from my desktop, wired to the C7800, to the EX8000 and restart it remotely, after which it connects again to the C7800 and the devices connected to it come on-line.
This has been going on for quite some time: over a year. It started happening maybe once a month. Over time that became once a week, then close to daily, and now daily or more often.
Recommendations?
  • plemans's avatar
    Did you set them up using wps?
    If so, factory reset the ex8000. Using the installation assistant to reinstall. during the install process, uncheck the "extend 2.4ghz" network. You'll still be able to use the 2.4ghz but it won't act as failover for the backhaul. You can also try changing which channel t he C7800 uses for the 5ghz in case theres issues/interference on it.
    • sfinn's avatar
      sfinn
      Guide
      Thanks - I'll give this a try and report back.
      Quick question: can you explain your thinking on the recommendation to disable the "extend 2.4 GHz network"?
      • plemans's avatar
        Reason I say uncheck that is the EX can use the 2.4ghz as failover for the 5ghz. So if there's issues with the 5ghz, it'll use the 2.4ghz. Problem is that the 2.4ghz is incredibly slow and significantly increases ping times. In my experience, its better to disable the 2.4ghz failover and find a stable 5ghz channel for the backhaul and just stick with that.
