Peggymom
Jul 03, 2020Initiate
X6S problem
I set it up as directed and used the same name (I am on a wireless network). Seemed like it was working could go from one side of house to the other. Problem, when I tried to go to amazon prime or Ne...
- Jul 04, 2020
Glad to hear the installation wizard got it up and running.
If you mark it as solved, it can help the next person with this issue.
Jul 03, 2020Guru - Experienced User
You can use the mesh function.
When many set it up, they use wps. which can cause issues when manufacturer's code things diffent.
Try re-running the setup wizard 1 more time. Use the mesh/single ssid/onessid function so it has the same name. Just don't use wps.
What firmware are you running?
What router is it connected to?
- PeggymomJul 04, 2020Initiate
We were able to get it to work with one name. Instead of setting it up with the app we use our iPad using an IP address and now it works great.
- plemansJul 04, 2020Guru - Experienced User
