Peggymom
Jul 03, 2020Initiate
X6S problem
I set it up as directed and used the same name (I am on a wireless network). Seemed like it was working could go from one side of house to the other. Problem, when I tried to go to amazon prime or Ne...
- Jul 04, 2020
Glad to hear the installation wizard got it up and running.
If you mark it as solved, it can help the next person with this issue.
Peggymom
Jul 04, 2020Initiate
We were able to get it to work with one name. Instead of setting it up with the app we use our iPad using an IP address and now it works great.
Jul 04, 2020Guru - Experienced User
