Loue557
Feb 19, 2021Aspirant
Xbox One won’t connect to Wifi Extender
Hello all. My Xbox One won’t connect to my ac1200 wifi range extender. it won’t connect to the 2GHz band or the 5GHz band, or the ethernet, yet my playstation will connect to all. why is this? sorry f...
Loue557
Mar 13, 2021Aspirant
Yes
DexterJB
Apr 13, 2021NETGEAR Moderator
Hi Loue557, do you have a static IP set on your Xbox? We'd recommend contacting our support team for a more immediate solution. The link and number below may help.
https://www.netgear.com/home/contact-us/default.aspx
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
