Nojboy715
Jan 25, 2025Aspirant
XR700 booster compatibility
I currently have the nighthawk XR700 router, which has been great despite the common configuration issue when power is cut. But I just moved into a new house that has a larger floor plan and much thi...
Nojboy715
That’s good to know, thanks.
Frustratingly, the areas that are in dead zones are on the other side of thick walls. I can run the EX7700 wirelessly boosting in an adjacent room, as it will be 1 floor closer than the current setup, I just won’t know the signal strength until I set it up.
I had an older set of Orbi RBK30 before I bought my nighthawk, but found they constantly dropped out over our 3 floor terrace.
My current virgin line comes in the loft, so is (technically) 3rd floor up. I can run Ethernet across the entire loft for a mesh system, as they don’t tend to have the range of routers with external antenna from what I’ve found.
The dead spot is the conservatory (2floors down, and through a Victorian thick walls), which I plan on running Ethernet to.
Do you think the mesh will work for the whole house (2 floors) from the loft if I hardwired one mesh unit in the conservatory?
So for the MK model, 2 in the loft, either side, then one in the conservatory through the thick wall.
I just worry the range won’t be strong enough, and each set is hundreds of pounds, so an expensive experiment.
If you could pick one wired single login option, what product would you choose? Or would you just throw a tri-band in a neutral location to get it through the wall
Thanks for your input, it’s much appreciated
Jan 25, 2025Guru - Experienced User
Still got your orbi system? they are much better hardwired in and would give you some rough coverage figures before buying a more expensive system. The XR700 is only faster in close range versus the older system.
Reason I say that is the broadcast strength has been set for a while. The AX and BE systems (wifi 6/7) didn't increase the broadcast power so coverage isn't much improved.
What actual speeds do you pay for? Picking up an older orbi system and getting some second hand satellites for increased coverage might be a better option than buying new if you're putting in some hardwired lines. My older orbi's were fantastic up to 800-1000mbps speeds. After that, i needed to upgrade my system but lower, they were great with the wired in satellites.
- Nojboy715Jan 25, 2025AspirantVery helpful, thanks. I’ll pull the Orbi out of storage. It’s an old one, but hopefully it improves coverage.
I pay for a 250 line, so incoming isnt crazy numbers. I just need relatively low ping on 2 gaming setups for the kids upstairs, then the rest is just streaming 4K in various rooms.
I’ll try it out for coverage at least, then I’ll know if I need to invest in an Ethernet mesh system or if a triband netgear second router would work just as well if my Orbi covers the signal issue- plemansJan 25, 2025Guru - Experienced User
If you've only got 250mbps service, the orbi should still do fine. And with it hardwired in, it'll perform with the specs of the 50 series. I really loved my system with the hardwired backhaul. Seemed more stable than my BE system.
