Retired_Member
Nov 27, 2013XWNB5201 setup & roaming
I just purchased the XWNB5201 Powerline 500Mbps to N300 Wi-Fi Access Point for use with an existing Netgear WNR1000 Wireless-N router. It's for use in a large house with concrete walls. The WNR100...
Retired_Member
Nov 27, 2013Setup using different (non overlapping) channel than main router, use same SSID, use same passphrase and you should be able to move around without a problem. In wireless setup in PC check connect to more preferred network if available
