blackhole996
Aug 02, 2017Aspirant
! Suspicious activity- condensed Router log
Folks- newbie here..have a R6250 router running latest firmware...few wired devices and few mobile wifi devices using it. I noticed some suspicious remote LAN access records and the DoS attacks f...
- Aug 15, 2017
Hi blackhole996,
These logs indicate that the packet/traffic has been dropped by the router. Unless you are experiencing a drastic slow down of the Internet speed, this is normal.
Dexter
Community Team
DexterJB
Aug 15, 2017NETGEAR Moderator
Hi blackhole996,
Dexter
Community Team
- blackhole996Aug 16, 2017Aspirant
well..it does slow down internet but are there any checks or settings I can do to plug any holes in security?
- DexterJBAug 17, 2017NETGEAR Moderator
Hi blackhole996,
You can try contacting your ISP regarding this and check if they can have your WAN IP changed then check if the issue persists.
Dexter
Community Team
