Bobearth
Jan 31, 2016Aspirant
1 PC refuse to access router setting using default gateway (192.168.1.1)
Hi, 3 month ago, I purchasea WNDR4300v2 router and I got trouble acessing the router setting page using the defauld gateway (192.168.1.1). When I enter 192.168.1.1 in the address, chrome displa...
Mars Mug
Feb 01, 2016Virtuoso
You could check your PCs network settings to see if it is set to public or private, this can affect the PCs access to other network resources. Take a look at the ‘Network and Sharing Center’.
- BobearthFeb 01, 2016Aspirant
I can't find nything about private or public.
All I find is that my network is set to "home network"
On of Home networks, you can see other computers and devices on the network, your computer is discoverable, and you can create or join a homegroup.
I think it should be visible.
- Mars MugFeb 01, 2016Virtuoso
If you go to a Command Prompt and type ipconfig /all you will see the IP address allocated to the PC if DHCP is enabled, it will also tell you if DHCP is enabled. The IP address of the Gateway should be the address of the Netgear router which the computer is connected to. It should be a Private IP address;
https://en.wikipedia.org/wiki/Private_network
What is the brand and model number of the modem that the router is connected to?
- BobearthFeb 02, 2016Aspirant
DHCP is enabled, For my "Ethernet adapter Local Area Connection"
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
there also other adapter that I don't know what they are like:
Tunnel adapter isatap.
Media State . . . . . . . . . . . : Media disconnected
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
And the Modem that I use is a Thomson DCM475
