fivehundie
Mar 09, 2023Aspirant
1750 R6400
Does the AC1750 R6400 router support DOCSIS 3.1?
- Mar 09, 2023
The R series router is just a router only. No built in cable modem thus would not be any support for D3.1. However the R series router CAN connect to a separate cable modem that does have D3.1 support.
Mar 09, 2023Guru - Experienced User
- fivehundieMar 17, 2023AspirantGreat! I didn't know if the router would accommodate a D3.1 modem but thanks to you, I now know. Thank you!
- FURRYe38Mar 17, 2023Guru - Experienced User
đ
