Bassundegrace
Oct 31, 2021Aspirant
180 out of modem, max of 95 from r6400v2
From my laptop I am getting roughly 180mb down directly out of my cable modem, but when plugged into myr6400v2 behind the modem I get a max internet speed around 95mb. I restored the R6400v2 back to...
- Oct 31, 2021
I was right, apparently the isp modem can tell what kind of device it is. I got an express vpn subscription and uploaded their firmware for my router. Items in the no VPN group now get roughly 170mb. That's dirty. The tech can say I get full speed from your laptop at the modem must be your network, and just walk right out your house placing the blame on you, when they are throttling by device type.
Oct 31, 2021Guru - Experienced User
What cable modem do you have?
have you tried replacing the cable between the modem---router and router---device?
I've seen sketchy cat 5e cables limit the connection to 10/100 versus gigabit.
Bassundegrace
They are cat 5e, tried a few different cables. Modem sb6190. Going to try and swithc the DNS to cloudflare and see if that does anything.
- plemansOct 31, 2021Guru - Experienced User
Try a cat 6 cable.
You can also log into the router and check connections.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
