Daladier
Feb 12, 2022Aspirant
192.168.1.1 IP Address does not work.
192.168.1.1 IP Address does not work when trying to login and update the name of the wifi and/or password. I went to the routerlogin.net to search for support, but my serial number doesn't even regis...
Feb 12, 2022Guru - Experienced User
you have the c7800?
If so, try 192.168.100.1
If that doesn't work, what modem/router do you have?
