Daladier
Feb 12, 2022Aspirant
192.168.1.1 IP Address does not work.
192.168.1.1 IP Address does not work when trying to login and update the name of the wifi and/or password. I went to the routerlogin.net to search for support, but my serial number doesn't even regis...
Feb 12, 2022Guru - Experienced User
you have the c7800?
If so, try 192.168.100.1
If that doesn't work, what modem/router do you have?
Daladier
Unfortunately, 192.168.100.1 did not work either (404 Not Found). 192.168.1.1 did initially work during set up, and then stopped after I got everything up and running.
You are correct tho, I'm using the C7800. Nighthawk X4S-AC3200 Wifi Cable Modem Router
- plemansFeb 12, 2022Guru - Experienced User
Is it working?
You could always try a factry reset
- DaladierFeb 12, 2022Aspirant
It did not work. Was on the phone for 2 hours with a netgear representative, and all he did was ensure my wifi stopped working altogether. No call back either. I've decided to fix the issue myself and return the equipment today.
- wcalifasFeb 12, 2022Prodigy
on the command prompt type ipconfig and it will tell you the default gateway(i.e. 192.168.x.x)
