Daladier
Feb 12, 2022Aspirant
192.168.1.1 IP Address does not work.
192.168.1.1 IP Address does not work when trying to login and update the name of the wifi and/or password. I went to the routerlogin.net to search for support, but my serial number doesn't even regis...
Daladier
Unfortunately, 192.168.100.1 did not work either (404 Not Found). 192.168.1.1 did initially work during set up, and then stopped after I got everything up and running.
You are correct tho, I'm using the C7800. Nighthawk X4S-AC3200 Wifi Cable Modem Router
Feb 12, 2022Guru - Experienced User
Is it working?
You could always try a factry reset
- DaladierFeb 12, 2022Aspirant
It did not work. Was on the phone for 2 hours with a netgear representative, and all he did was ensure my wifi stopped working altogether. No call back either. I've decided to fix the issue myself and return the equipment today.
- wcalifasFeb 12, 2022Prodigy
on the command prompt type ipconfig and it will tell you the default gateway(i.e. 192.168.x.x)
