ranjayQ
Nov 29, 2019Follower
192.168.1.1 won't work & not able to Login Netgear router
I don't know How but i amnot able to login netgear router. i have tried Routerlogin.com & .net Also 192.168.1.1 but no help. i amnot able to access netgear router admin page. what should i do ? i am ...
- Nov 29, 2019
Hello ranjayQ
Since you are using Windows 10 computer & as per my understanding You are not able to Login netgear router admin console for you to change the settings so this is How You Should go about this issue -
- Restart your computer & refrsh the Browser (If Possible Try a different Browser ). make sure 192.168.1.1 is the default Ip Address & computer or Phone is connected to netgear router Before you access the setup page.
- Go to 192.168.1.1 & access the Router Admin page using the default Login credentails. default Username is = admin , Password = password
- Make sure You type the default Ip Address at the top of your Web address in (URL Box ) Once Logged in you are free to make changes as you wish.
- if nothing works Please Reset the netgear router to start fresh & i am sure that Would Be Work Just Fine.
rakeshser
Nov 29, 2019Initiate
Hello ranjayQ
