jpearlman
Dec 02, 2020Follower
2.4 GHz not broadcasting on Nighthawk R7900P
I have followed the steps listed in this post: Netgear Community 2.4 stopped broadcasting I still can not get the 2.4 band to broadcast. The light on the Nighthawk 2.4 is on but it is not broadc...
Dec 03, 2020Guru - Experienced User
You're not actually on the latest firmware.
I'd recommend installing version 1.4.1.64 of the firmware over a hardwired connection. Then do a factory reset and clean install (not from a backup configuration).
