hnoble
Nov 20, 2020Aspirant
2.4 ghz not password protected
Currently, my 5 ghz is password proteted but my 2.4 ghz is not. When I go and select this security option WPA2-PSK [AES] and add a password on it, it does not show that a password is needed. I would ...
- Feb 20, 2021
Thank you for the update. Did you try to reset the Cable gateway? If not yet please do so and set it up again and see if that resolves the issue.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
hnoble
Feb 18, 2021Aspirant
antinode
Feb 18, 2021Guru
> [...] I there a way to make it secure beyond what I am doing?
There should be, but how many of us know what you're doing?
> [...] I have tried resetting multiple times. [...]
"tried" how, exactly? What happened whan you did whatever you did?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Factory Settings" and "Specify Basic WiFi Settings". Is there a
non-empty passphrase for both radio bands?
