hnoble
Nov 20, 2020Aspirant
2.4 ghz not password protected
 Currently, my 5 ghz is password proteted but my 2.4 ghz is not. When I go and select this security option WPA2-PSK [AES] and add a password on it, it does not show that a password is needed. I would ...
- Feb 20, 2021
Thank you for the update. Did you try to reset the Cable gateway? If not yet please do so and set it up again and see if that resolves the issue.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
hnoble
Feb 19, 2021Aspirant
I have already read through the documentation and reset to factory settings as described in the manual. That is why I have asked this question on the forum, as the current documentation was not helpful in resolving my issue.
olympos1625
Feb 20, 2021NETGEAR Employee Retired
Oliver
Community Team
