dreamtuner
Sep 05, 2024Aspirant
2.4 GHz Vanished on Netgear R6220
My R6220 is on Firmware v1.1.0.114_1.0.1. Since a few months ago, none of my devices could find the 2.4GHz SSID no matter what. The 5GHz band is working perfectly fine, however. Below are the steps I...
dreamtuner
Thanks. I have already set it up from scratch, but unfortunately the problem persists. The default name (SSID) has also not been detected by any of the devices as well. My first thought was that it's done after all these years of nonstop use.
Sep 05, 2024Guru - Experienced User
Can disable the wifi radios on the router and install maybe a EX series model wifi extender that has AP mode and connect it up for wifi as an alternative solution, otherwise, maybe time for something new.
