dosinia's avatar
dosinia
2.4GHz and 5GHz band LED lights consistently blink causing intermittent wifi connection
  Hello, and thank you for taking the time to read my post!   I've been using my Netgear router for about five years now and it's been great. Normally, I will work on several wireless devices in c...
  • netwrks's avatar
    Oct 15, 2016
    Try resetting the router to factory default, to see if it sorts out the wireless. The wireless could be failing. Five years is a long time in a routers life..
