dosinia
Oct 14, 2016Aspirant
2.4GHz and 5GHz band LED lights consistently blink causing intermittent wifi connection
Hello, and thank you for taking the time to read my post! I've been using my Netgear router for about five years now and it's been great. Normally, I will work on several wireless devices in c...
- Oct 15, 2016
Try resetting the router to factory default, to see if it sorts out the wireless. The wireless could be failing. Five years is a long time in a routers life..
netwrks
Oct 15, 2016Master
dosinia
Oct 15, 2016Aspirant
I reset the router to its factory settings. It took me a while after I did this to get things going again since I also had to reconfigure the connection between the router, modem, and wired computer. After several reboots, I am having the same problem. I failed to mention that the Wifi LED light on the router is OFF -- this may explain why both wireless bands are blinking the way they are.
I went to the routerlogin.net site and confirmed that both bands have the "Enable Wireless Router Radio" box checked (under Advanced Setup --> Wireless Settings). I also pressed the Wifi button (on the back of my router) to turn it OFF and then ON.
I think at this point it's time for a new router, but I welcome any other steps you think I should try. Thanks again for your help.
