SatishR6220
Feb 25, 2017Aspirant
2.4ghz not connecting R6220
Hi Netgear Community, 2.4 ghz bandwidth has stopped connecting on all devices (laptop, ipad, iphone). 5 ghz is fine. I tried factory reset, it didnt help. Firware is upto date (V1.1.0.34). When ...
- Feb 28, 2017
Hi SatishR6220,
1. Are the devices able to connect to the 2.4GHz band but are not able to go online?
2. You can try changing the wireless channel.
3. You can try changing the mode.
4. You may also try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
DexterJB
Mar 05, 2017NETGEAR Moderator
Hi SatishR6220,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
SatishR6220
Mar 09, 2017Aspirant
Hi Dexter,
I read one one of the blog topic to hold on reset button for 20 sec. (earlier I had rest just holding it probably 4-5 sec). I dont know how but it worked after resting with '20 sec' rule.
I will update after testing it for one more week.
Best
Satish
- DexterJBMar 13, 2017NETGEAR Moderator
Hi SatishR6220,
Thank you for providing an update. Please keep us posted.
Dexter
Community Team
