SatishR6220
Feb 25, 2017Aspirant
2.4ghz not connecting R6220
Hi Netgear Community, 2.4 ghz bandwidth has stopped connecting on all devices (laptop, ipad, iphone). 5 ghz is fine. I tried factory reset, it didnt help. Firware is upto date (V1.1.0.34). When ...
- Feb 28, 2017
Hi SatishR6220,
1. Are the devices able to connect to the 2.4GHz band but are not able to go online?
2. You can try changing the wireless channel.
3. You can try changing the mode.
4. You may also try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
SatishR6220
Apr 03, 2017Aspirant
Hi Dexter,
I used it nearly 3 weeks now.
It worked on both the bands for 4-5 days without any interruption however after that wifi signal is not constant. The connection gets disrupted every 5-10 min.
It's quite frustrating. I thought this is best wifi router which should be plug and play.
I don't know how to solve this problem? and it's quite costly router!
Regards
Satish
Regards
Satish
- DexterJBApr 04, 2017NETGEAR Moderator
Hi SatishR6220,
May I know if you have tried the other steps other than resetting the router?
Dexter
Community Team
- DexterJBApr 12, 2017NETGEAR Moderator
Hi SatishR6220,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
