SatishR6220
Feb 25, 2017Aspirant
2.4ghz not connecting R6220
Hi Netgear Community, 2.4 ghz bandwidth has stopped connecting on all devices (laptop, ipad, iphone). 5 ghz is fine. I tried factory reset, it didnt help. Firware is upto date (V1.1.0.34). When ...
- Feb 28, 2017
Hi SatishR6220,
1. Are the devices able to connect to the 2.4GHz band but are not able to go online?
2. You can try changing the wireless channel.
3. You can try changing the mode.
4. You may also try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
Major_Woods
Aug 15, 2022Aspirant
I'm having the same issue. I've manually uploaded the firmware & factory reset multiple times. I still can't connect to 2.4 wifi. It keeps saying my credentials are wrong, but they're not. I've tried changing them too, but that didn't do anything.
- michaelkenwardAug 16, 2022Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems and that hasn't had any new messages in five years.
There is a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
