Viperlocc
Dec 30, 2021Guide
2 router 1 network and keep plex working
I recently purchased an orbi rbr850 mesh wifi system to replace my nighthawk gaming router since it started having issues and would only give half of the stuff in the house an ip address. I set...
- Dec 30, 2021
figured it out needed to go to run and do the //readyshare
Viperlocc
Dec 30, 2021Guide
I thought I read some where that the xr couldnt connect to the orbi that way but I will give it a try, thanks :)
Viperlocc
Dec 30, 2021Guide
that worked thank you
Any idea as to how I can access my plex shortcut folder again? I used to access it by a shortcut folder \\192.168.1.1\USB_Storage\Plex
now since the main orbi is 192.168.1.1 it doesnt work anymore and the only way I can login the xr700 is by going to http://www.routerlogin.com which I am not sure if that will work as a shortcut for a folder to the connected hard drive.
