dHj-1959's avatar
dHj-1959
Follower
May 12, 2019
28P1057B03407 installed outside cameras downloaded then ask wifi put netgear 4got password
  • so you forgot your wifi password?
    You can log into the device through your browser to see you wifi password.
    You don't put what router model you have.  Try going to routerlogin.net    default login is admin   default password is password.
    If you've changed the login to the router, then you'll probably want to reset the device and start over. Some devices have a forgot login password option but if you haven't set it up, it doesn't do you much good.
    go to netgear.com/support and type in your model number. It'll have instructions for the manual that has more details.
1 Reply
  • plemans's avatar
