Sezro626
Jul 22, 2020Guide
2nd Wifi Access?
I recently got a new modem. I previously had access to 2 Wifis a 2.5 and 5.0. Now I don't know how to access my 2nd wifi. One of my wifi just show a lot of letters and numbers and I'm not sure how t...
- Jul 23, 2020
It could be yours. But it isn't 5ghz if you have the wnr1000.
Sezro626
Jul 22, 2020Guide
My Previous modem was a Model TG1682G Arris
My New Modem is Motorola MB7420 16x4 686mbps DOCSIS 3.0 Cable Modem
My router is putting out 2 signals because there is one wifi available that has a long series of numbers and letters when I set up my modem and router. I don't know how to set it up on the Netgear Smart Wizard.
Jul 22, 2020Guru - Experienced User
Sezro626 wrote:My Previous modem was a Model TG1682G Arris----which is a dual band modem/router combo device.
My New Modem is Motorola MB7420 16x4 686mbps DOCSIS 3.0 Cable Modem----which is a modem only device. no routing or wireless capability
Your wnr1000 is a single band n150 device. not sure where the other band is or whats broadcasting it but its only a single band device. Should you want to use 5ghz, you'd need to upgrade to a better router.
- Sezro626Jul 22, 2020Guide
plemanson my first post I posted a screenshot of the available Wifis. I'm not sure how to embed the image. That long wifi with the numbers and letters appeared when I was setting up my internet. I thought that was supposed to be my 2nd wifi. Is that something that came with my internet? That's what's confusing to me. Even setting it up I kept reading the IP should start with 192. but my current wifi uses 172 which is how I got into the Setup wizard.
- plemansJul 23, 2020Guru - Experienced User
If you're going MB7420------>wnr1000
Then you're only going to have a single band setup. Because the MB7420 doesn't have wifi or any routing functions and the wnr1000 is single band. Maybe its someone elses. But its not a 5ghz network because none of your devices support broadcasting 5ghz.
- Sezro626Jul 23, 2020Guide
plemans wrote:If you're going MB7420------>wnr1000
OK. I'm pretty sure the other wifi is mine also. If I turn off my router it dissapears with the one I set up also. But thanks for the help.
