Sezro626
Jul 22, 2020Guide
2nd Wifi Access?
I recently got a new modem. I previously had access to 2 Wifis a 2.5 and 5.0. Now I don't know how to access my 2nd wifi. One of my wifi just show a lot of letters and numbers and I'm not sure how t...
- Jul 23, 2020
It could be yours. But it isn't 5ghz if you have the wnr1000.
Sezro626
Jul 23, 2020Guide
plemans wrote:If you're going MB7420------>wnr1000
Then you're only going to have a single band setup. Because the MB7420 doesn't have wifi or any routing functions and the wnr1000 is single band. Maybe its someone elses. But its not a 5ghz network because none of your devices support broadcasting 5ghz.
OK. I'm pretty sure the other wifi is mine also. If I turn off my router it dissapears with the one I set up also. But thanks for the help.
Jul 23, 2020Guru - Experienced User
